Fishy_Old_Man's avatar
Nov 16, 2014
Direct TV HD Satellite tripod
I am going from a standard Direct TV satellite dish to a HD Slimline dish. Can I adapt my Winegard tripod to work with the Slimline dish?
If not, can you recommend a tripod?
Thanks for any help you can provide.
Fishy
  • That's like I use. You can get the tripod at Lowes for around $80.
    I found a used one on CL for $30. I made my bracket for $5.
  • Get one of these http://tv4rv.com/sunshop/index.php?l=product_list&c=1. You will be glad you did.
  • I use mine on asphalt often so I can't drive stakes which seems like a pain anyways.
    Mine has never fallen over. I just spread the legs out very far.
    An Align a site is a $160 piece of un neccesary plastic.
    I use Dishpointer on my iphone.
  • Big Katuna wrote:
    The little tripod isn't sturdy enought. The Dish mast needs to be completely plumb to get a good signal o n all three sats. Not necessairly true. Usingma tool like the Align-A-Site eliminates the need for leveling the tripod
    I use and recommend a surveyors transit type tripod. It levels quickly and is very sturdy.
    Mine has never fallen over. There is a wide variety of decent heavy duty tripods that work very well. The key is heavy enough to be stable in all conditions, and the ability to secure it to the ground. I use 12 inch spikes through the feet
    I found a used one for cheap and made a plate to bolt the dish to out a a 4" x 13" 1/4" aluminum plate.
    You can buy the completed unit on rvsat.com or something like that $150
  • The little tripod isn't sturdy enought. The Dish mast needs to be completely plumb to get a good signal o n all three sats.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,798 PostsLatest Activity: May 01, 2025
