fishkiller's avatar
fishkiller
Direct tv questions again
So I have direct tv at home with nfl sunday ticket. I Cant take the hr 34 dvr with me when camping due to the kids,
Can I get an hd receiver from on my home account from direct tv or ? and can I view nfl sunday ticket will camping?? I know if I go more than 100 mi or soo I will loose my local channels that's ok. Do I need to carry the same size swm dish I have at home?? Or should I just get a tailgater and dish pay as you go...more confused
  • Ivylog's avatar
    Ivylog
    Explorer III
    You are a wizard, thanks for linking my posts. OP you do not have to get the exact same receiver from DirecTV. A smart phone satellite app will let you see where the three satellites are and if anything is blocking your view of them making it much easier to set up a portable tripod dish. Using a level to make sure the pipe for the dish is perfectly upright will make getting all three satellites easy by just peaking 101.
  • fishkiller wrote:
    Soo based on what I read here bill and ivydog A small 18 x 22 dish with a sl3 LNB will work to get hd sats. I should be able to get an additional hd receiver... from direct tv without to much trouble and monthly cash..I don't need a genie but I did read somewhere that you have to have the same receiver 1-hr-34-700 as the stick house?? Am I on the right track...Thanks
    You need to add an additional receiver to your existing account and DirecTV will not let you add a 2nd Genie as it will not work with your current antenna (to many tuners for the LNB to support). You can add an HR24 dual tuner DVR and you will be able to use that in the RV.
    Thanks that's what I needed to know...will call direct tv today to start process. Thanks again
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
