INDIAN_CREEKER's avatar
Jan 27, 2014
Direct TV to Dish Network
We have a Park trailer, Salem Villa. It was prewired at factory for Satellite. We had Direct TV hook us up and had no problems using the factory hookups. Now we are changing to Dish Network. Can I expect the same easy hookup with Dish Network?
Or can I expect the installer to want to start drilling new holes for ho reason at all?
Thanks,
Dave
  • Bumpyroad wrote:
    the only time new cables might have to be run is if you put in a dual receiver such as 625 that my installer said takes a special cable so signals can be bi directional or some such.
    bumpy
    Our previous 625 used regular RG6 cable...nothing special. Just recently traded it for a 722K and still using the same cable. Of course we use HDMI from the receiver to the TV.
    For the OP, from DTV to DISH would be as Bill mentioned. Not a big problem at all.
    Ron
  • What kind of antenna will you be using and what kind of receiver do you plan to use? If you are saying you have a permanent park model unit with a regular home antenna mounted then Dish will replace that antenna with a Dish antenna and the setup will be easy peezy!
  • the only time new cables might have to be run is if you put in a dual receiver such as 625 that my installer said takes a special cable so signals can be bi directional or some such.
    bumpy
    Thanks,
    Dave
    As long as RG6 coax is being used in your trailer, I can't see that there should be any problem. Having said that, I am not a satellite "expert", I just use it.:)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
