MX955's avatar
MX955
DirectTVwith Winegard combatibility question
We recently purchased a motorhome that has a Winegard Minimax RT8035T satellite on it and I am trying to get my HR23 receiver to work with it but not having any luck. The receiver is activated and works fine in the house. I guess my question are these two compatible and if so what do I need to do. I keep getting errors saying it cannot find signal.I am very new to this whole satellite tv thing and don't know very much,so any help with what would work would be appreciated ...Thanks!
  • I have done everything suggested in above posts & still having same problem..
    Checking signal strength I get all zero's?
    I have verified dish is powering up & moving & proper cable is going from "main" from Minimax dish to the receiver "satellite in 1".... Any other suggestions?
  • I just got a new dish today from Al's RV in Az. $400 less than the same one from another dealer on Grand ave. A lot of money for the same one installed.
  • The HR23 should work. You must first go into the receiver setup menu and set the antenna type to oval 3-LNB and the switch type to multiswitch. Once this is done, go to signal strength and signal meter before turning on the antenna. Now turn on the antenna and let it lock to 101. Once complete you can click the continue buttons all the way to the end.
    Just be sure that you go into the receiver setup menu and click on Display>Preferences and then Hide HD channels so your SD channels become available.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
