- edatlantaExplorer IIA bit of effort is worth it for me since I watch a lot of TV and won't be without HD and I don't like Dish. Soooooo, Slimline and Tripod. Aiming it is a 5 minute operation after I get the tripod and dish to the site. As was said previously, after setting it up a few times it gets very easy. I also use a wireless baby monitor vs a high priced meter. Works for me.
- 2oldmanExplorer II
TechWriter wrote:
It doesn't happen with most guys, because it takes a bit of effort.
Mmmm . . . that's not going to happen with this guy.(sat setup) - Bill_SatelliteExplorer IINo SWM kit would be necessary with the G2(+) and an HD DTV receiver for SD reception. The only reason that might make any sense is if the receiver was a DVR.
- TechWriterExplorer
Bill.Satellite wrote:
Winegard now has a G2+ which is a big set up from the G2 so be sure if you go that route to pick the +.
Thanks . . . I checked the manual & there's a SWM kit available if necessary. Looks good.Bill.Satellite wrote:
If your friend does not mind taking 20 or so minutes to set it all up you CAN get full HD with a home style antenna setup on a tripod. There's a bit of a learning curve but gets pretty easy to do after a few setups.
Mmmm . . . that's not going to happen with this guy. - TechWriterExplorer
Dick_B wrote:
This has been discussed previously. Search this Forum for `Winegard G2' etc.
Thanks dick - Bill_SatelliteExplorer IIWinegard now has a G2+ which is a big set up from the G2 so be sure if you go that route to pick the +.
If your friend does not mind taking 20 or so minutes to set it all up you CAN get full HD with a home style antenna setup on a tripod. There's a bit of a learning curve but gets pretty easy to do after a few setups. - Big_KatunaExplorer III'd say the Winegard Pathway X2. That way if he ever comes to his senses, he can get DISH HD both eastern and western arcs.
- Dick_BExplorerThis has been discussed previously. Search this Forum for `Winegard G2' etc.
- 2oldmanExplorer IINot getting HD will be a bummer. Tell him to get a Slimline and tripod and learn to aim it. After the first 10 tries it gets easier.
- donn0128Explorer IIDepends on receiver he has. Older non SWMs will work, but newer ones wont.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
