- 2chiefsRusExplorer
Bill.Satellite wrote:
If DTV truly ended DNS service they would also be able to convert NY and LA to spot beam as doing the CONUS broadcast would no longer be necessary. This would add additional capacity to their existing satellites.
Bill that is exactly what I was thinking. Even if I went to the trouble to find an LA or NY address that AT&T would accept it might work for a while until they change those to spot beams like the rest of the country then I would be right back to where I will be on June 1st. - 2oldmanExplorer II
pigman1 wrote:
Valdez dish elevation= 11°. I haven't checked but I'm not sure my gauge even goes that low!
but it doesn't help when I'm in Valdez, Alaska trying to get network programming - pigman1Explorer
was_butnotnow wrote:
I understand, but it doesn't help when I'm in Valdez, Alaska trying to get network programming (DNS) from LA. We're just a bit outside the spot beam area for LA.
I see on another forum monacoers.org this also works on both LA spot beam and also NY spot beam if you declare a local service address in each area.
I would rather get NY locals for earlier recording times.
Shall see if all this goes away on June 1 - Bill_SatelliteExplorer IIIf DTV truly ended DNS service they would also be able to convert NY and LA to spot beam as doing the CONUS broadcast would no longer be necessary. This would add additional capacity to their existing satellites.
- was_butnotnowExplorerI see on another forum monacoers.org this also works on both LA spot beam and also NY spot beam if you declare a local service address in each area.
Shall see if all this goes away on June 1 - 2oldmanExplorer IIwill do
- was_butnotnowExplorerLet us know on June 1 if it goes away.
Thanks - 2oldmanExplorer II
I took a chance that the LA spot beam is also the DNS feed. It made sense to me. I winter within range of LA locals, so if I was wrong at least I'd have locals for 6 months.
I can't believe they are doing the LA spot beam all over the country.
Any ideas why this is working for you?
Did you have any trouble changing your service address to LA and did they want to come and set up a new dish?
Did you just pick a generic address or do you have a property in LA?
All most enlightening...
No, I just kept calling until I found an operator who knew what to to.
It's possible I got the spiel about a move request or a service call.. I really don't remember. If I did I would have hung up and called back.
I randomly picked an address of what looks like a mobile park. - was_butnotnowExplorer
2oldman wrote:
No DNS.
Location= 4 corners NM
Not paying any extra for anything.
WOW Thanks for the screenshot
All most enlightening... - 2oldmanExplorer IINo DNS.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
