campermama wrote:
I still have the D-12 and use it on the road with the King Quest 4100, I don't get any local stations (wish I did). My only other receiver is the H-25 but don't want to have the same problems as GTO66 did, plus I don't have the SWM8 kit.
So I'm hoping somebody comes up with a solution to all this when SD is obsolete.
Maybe I will just have to go to some high powered antenna (if there is one) and forget about satellite while on the road.
Talk to nearby neighbors and see if they have a solution for OTA.
The OTA switch to HD resulted in many stations on UHF with more limited range and line of sight required. Basically you get HD or not while SD could be snowy but still viewable.
