CA_Traveler's avatar
CA_Traveler
Explorer III
Jan 11, 2014
DirecTV HR 44 Receiver
The HR44 receiver did have many problems and there are various posts to that effect on the internet.
Yesterday I asked a DTV Installer (not a vendor) about his view on the HR44. He said DTV had a lot of problems with the receiver but starting one month ago with the latest software update he has had no problems. I even asked about the reported slow channel switch time and he said it's faster than any other receiver.
So with this I'm again considering a HR24 to HR44 upgrade. The home slimline 5 dish would be converted to SWM and the MH is already SWM.
I believe the HR44 supports picture in picture for 2 channels. That would be nice to have for sports. However most of the time we pre record and then skip the commercials.
He also surprised me about the 5 channel recording. For every remote client that is connected the channel recording is reduced by one. So if you had 2 remote clients say in two different rooms you would be limited to 3 channel recording. Not a problem for us as we only use one TV in the house and one in the MH.
I need to verify the record/watch capability. Can you watch 2 and record 3 for example (no clients).
In addition DW said that we'll keep the HR24 active until all recorded shows have been viewed. :C
  • Not sure of the info you received, but no matter the setup you will always be able to watch/record 5 channels simultaneously. I have the Genie plus an H25 so I can watch/record 6. I like having the H25 as a back up since the Genie would be the only satellite receiver if you have Genie and clients whereas I could at least watch one DTV channel if my Genie died by putting the H25 in its place.
    Clients are NOT satellite receivers so if you have a Genie and 17 clients you will still be able to watch/record 5 channels on the Genie.
