CA_Traveler
Oct 06, 2016Explorer III
Please edit your post and reduce the picture width to 600.
The dish appears to be SWM in which case you connect up the power inserter. For a single receiver you do not need the SWM splitter. The coax is connected to the left hand connector for SWM.
Here were my HR24 settings, yours could vary. For #6 it might help to display both SD and HD to start. #7 must match the dish, dual is because there are 2 tuners.
3. Menu-Settings & Help-Settings-Display-TV Ratio: Widescreen 16:9
4. Menu-Settings & Help-Settings- Display -TV Resolutions: Check all resolutions.
5. Menu-Settings & Help-Settings- Display – Video: On, Pillar Box, Dark Gray
6. Menu-Settings & Help-Settings-Display-Preferences-Guide HD Channels: Hide SD duplicates.
7. Menu-Settings & Help-Settings -Satellite-Repeat Satellite Setup: Dish setup: Option 17 Swimline-3S(SWM), 01: SWM, Dual.
Hope this helps.
Hope this helps.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
