Djsrcy's avatar
Djsrcy
7pin wiring problem. Please help!
I have a new to me travel trailer. I am having a few issues with the wiring. Let me list those and then I'll list what I have done so far.
1. When headlights are on, running lights are not.
2. When I hit the brakes, the running lights come on.
3. When I use right turn signal, running lights flash.
4. left tail light is out completely.
Here is what I have done.
1. I have confirmed the tv wiring is fine.
2. I cut the 3 grounds that were attached to the trailer near the front. I restripped, added new ring connectors, cleaned up the contact point on the trailer, and used a new screw.
3. Did the same for the grounds coming off of each tail light going to the frame.
4. I replaced both rear bulbs.
5. I pulled off the tail light housings and cut and redid the connections for those too.
6. I replaced the 7pin plug.
7. Opened the junction panel under the camper and everything LOOKS good.
I was and kind of still am convinced that this is a ground issue but have no idea what to check or how to check it. Been messing with this for days. At my witts end. ANY help is appreciated.
Thanks, Djsrcy
