drsteve
May 10, 2018Explorer
wnjj wrote:drsteve wrote:Djsrcy wrote:
Thank you guys!
The plug is not molded. I just replaced it. It matches the tow vehicle. I am on my way to get the light tester and will make sure I have a good ground. It is an 04 timber lodge 26RLS. Also, my truck display says “trailer wiring fault”
I’ll let you know how it goes,
Thanks again
I'm beginning to suspect the previous owner may have the trailer wired so it worked with his own miswired truck...
I agree. It sounds like the right turn is connected to the running lights, among other things.
Don’t assume anything about wire colors. Though the 7-way diagrams tend to show “standard” colors, all bets are off with trailer manufacturers. You need to get an external source of 12V and connect the negative to the known ground and then briefly touch the positive to each of the other wires one by one and see what lights up and listen for the brakes.
You can do this at the trailer plug or junction box.
What he said. Your truck says the trailer wiring is at fault, and it sure sounds like it is. Apply 12v to each wire one at a time at the trailer connector, and see what happens.
44,070 PostsLatest Activity: Jul 21, 2026
