77rollalong
May 11, 2018Explorer
or you could use the rv battery as well to run the lights, then you only need a wire from the positive post of the battery, maybe an idea to have a fuse inline just in case you hit the ground pin, maybe also an idea to check the one light bulb as well, as i have see a bulb filament break and short to the other filament...
44,070 PostsLatest Activity: Jul 21, 2026
