mike-s
May 11, 2018Explorer II
Djsrcy wrote:That will work, until you connect the positive wire to the ground on the 7 pin and make sparks fly.
okay. When the wife gets home I will use her battery and a couple wires.
So I will connect a wire from her car's negative post to a known ground on the CAMPER and then connect a wire from her car's positive post and touch each wire on the 7 pin. correct?
44,070 PostsLatest Activity: Jul 21, 2026
