Bill_Satellite
Jan 22, 2017Explorer II
siggyd777 wrote:
My RV neighbor has a new slimline dish with one LNB dish close by my RV. It is good for HD.
Can I ( I have his permission) connect to an other of the 4 outputs and
connect to my H24 receiver, will I need some other inserter or other
adapters ??? ...that is the question!
I have a DOME on my RV (SD only) and I know how to reset my receiver for the new dish.
Thank you all for your reply's
Siggy
Yes, absolutely! If there are 4 outputs then it is not a SWM antenna so you can run 1 coax to your receiver, be sure you have your BBC installed on the H24 and you are good to go. If your home setup is SWM then you will not have a BBC (B-Band Converter) but you can pick one up for about $10. Also, if your home setup is SWM you will need to change the settings in the receiver to match the antenna type and set it to Multiswich and not SWM.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 23, 2026
