CA_Traveler
Sep 15, 2013Explorer III
Like2Travel wrote:You stated non SWM at home and you would use the 2 non SWM cables.
So, one cable or two?
In the RV with SWM you use one cable to the HR24 input 1 from the SWM brick and of course the dish cable goes to the other brick connector.
The main thing that you need to get right in the settings is the dish type, option 17. Have you done that? The other is you don't use the B band converters with SWM.
It's actually very quick to change the settings once you understand what to do. Of the 7 steps I posted above most are the same between my two current HD TVs. The biggest changes occurs when I connect my 18" portable SD dish and in the past I also had a SD TV.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
