Like2Travel
Sep 18, 2013Explorer
First, thanks for all the help. I finally got a chance to work on it some yesterday. One, I do not have any BBCs in this setup. I know they have to be used at home but not on SWM. Second, I have run with two cables, the splitter, and the dish setting on SL3(3). I have also run the system without the splitter, one line to tuner 1, and the dish setting to SL3S(17). The DVR works the same on either of these setups. I have both tuners working and can watch and/or record on either tuner.
I still have what looks like a dish aiming problem that I don't understand. I have an align-a-site and have nailed the 101 with over 90s. Where I am, the tilt is supposed to be 67. When the tilt is at that angle, I do not get anything on the 99 or the 103. If I rotate the tilt as far as it will go(80), then I get a good(70s) signal on the 99 and nothing on the 103. If I rotate the tilt back to around 40 degrees, I get a week signal on the 103 and nothing on the 99. Any suggestions on this problem? Oh yes, on the DVR, I am not getting all of the channels. When I have the tilt at 80, I get all of the SD channels and 15 out of 43 of the HD channels. I am getting the 771 on the HDs that I cannot watch. Any help appreciated.
Thanks again for help.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
