Like2Travel's avatar
Like2Travel
Directv SWM SL3 System Not getting Signal on 103
I have Directv at home with two HR24 DVRs. They are non-SWM using a SL3. When I take my RV off, I take one of the DVRs with me. In the RV, I have a SL3 dish with a tripod. This system is SWM. I have only had this RV setup for a few months. When I first got the system, I tried everything out at home and it worked perfectly. Now I am out of my home area and it doesn't work. This is the second time that I have had this failure. The first time two months ago, I was having to shoot through a narrow opening in the trees. When it failed, I blamed it on that. Now, I am in another campground with zero trees and am having the same problem.
When I go into setup on the DVR, I put in that I am using an SL3 and SWM. THat seems to go OK. I am getting a warning message that says 'SWM not Registered'. With the dish aimed, I am getting 90's on the 101 dish, and 70's on the 99 dish, and nothing on the 103. The 103 shows up as 103(CA) and 103(CB). It shows no signal on 103 at all. And the system will never come on up where we can watch live TV.
I called Directv. The lady told me that the problem had to do with my being out of my home area? She told me to wait until I get home to make a call for a tech to come out and fix the problem. I and DW want it fixed now, not a week from now. She said that the DVR should come on up with everything except any locals but it doesn't come up. We can watch recorded stuff but no live TV.
Any help appreciated.
  • therink wrote:
    So you have Slimline 3 dish on tripod with SWM lnb? Do you have the power inserter in your rv and is it powered?
    Yes, I have a Directv Power Inserter. When I set it up all at home, it worked.
  • I assume that you know you don't need B-band converters with a SWM setup. And the Power Inserter you need is a PI-21, not the 29.
  • So you have Slimline 3 dish on tripod with SWM lnb? Do you have the power inserter in your rv and is it powered?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
