accsys
Feb 05, 2014Explorer
Ivylog wrote:
Folks, unless you are way north in the US you DO NOT need the big slimline dish to get HD now that you only need sats 99, 101, 103. A 18x20 multi sat dish which has the tilt adjustment plus a SL3 lnb (which bolts right on) is all you need (see my first post). You can use your old 18" tripod and if it has adjustable legs which you really need to plum the mast. If you put one leg 180 degrees from the sat azimuth you can fine tune the elevation by changing this leg's length slightly once you get a signal.
OP, with a little practice it's not that hard to get the three usable signals you need for Direct HD.
The OP said he needed SWM and I don't believe your system will work with the new Genies (SWM) without adding a SWM8 to the antenna feed of your system. How far North will the 3LNB work on the old 18x20??
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
