Jimdee's avatar
Jimdee
DirecTV SWM3 Slimline Dish on Tripod--How Hard Is It to Aim?
I'm switching from DISH to DirecTV because of the distant network service going away on DISH. The installer is coming on Friday to install my receiver and a SWM3 slimline dish on my tripod. If any of you use a setup like this I'd like to know how hard/easy it is to aim the dish, and the process you use to aim it. Do you use a separate meter, or do you use the meter on the TV screen? Thanks.
    I do. To see the screen from outside the RV, I use a Swift Hitch camera. As for how difficult it is, that is largely dependent on the stability and level of the tripod. Without that, it's realllly difficult.
    Perhaps, one day, Directv will decide to put the beeps back in the receiver. Never could understand that one.
    Seems odd that an installer would be mounting the dish on a tripod for you. The first strong wind is likely to either move the dish or worse, knock it over.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Is the post on your tripod 2"? The slimline dish requires a 2" post which I doubt you have. So, have them install the slimline dish on your house although you want your account for a RV (Not your house) so you can get the East and West feeds.
    The installer probably has one of these for free and it will fit on your smaller tripod. Buy a SL3 lnb that will fit on this smaller dish which is all you need to get HD since you are not in the north.
    Getting Direct HD is not that hard once you set the tilt on a post that is plumb. I use a $14 meter and all you do is peak 101.
