Dayle1's avatar
Dayle1
Explorer II
Apr 04, 2018
DirecTV transponder problem
My DirecTV setup worked fine 10 days ago. But moved to a new campsite and on Sunday I set the system up again. I'm using an 18" round manual dish and signal meter to locate the 101 sat. I got plenty of signal strength on the meter, but nothing on the DirecTV setup menu. But when I scrolled thru all the transponders, 3 were actually working with signal strength between 77% and 85%. They were numbers, 28, 30 and 32. All the other transponders were zero.
Rebooting the system did nothing. DirecTV tech support was worthless. So, on a chance I ordered a new LNB thru Amazon. I just swapped out the LNB without disturbing the dish. Didn't bother to recheck the signal meter. But no change, the same 3 transponders have 80% to 84% strength and all others are still zero.
Seems strange that this is a receiver problem, but what else is there? Anyone have ny ideas or suggestions. DirecTV today says they don't make service calls for mobile setups, to call Camping World for help.
  • Dayle1 wrote:
    So is everyone saying it is possible to be on the wrong sat. and still get 3 of 32 transponders to show 80+% strength???
    Learned something new, on another forum one poster stated I was hitting 110W. He was correct, problem solved.
  • edatlanta wrote:
    I don't have to worry about finding the wrong sat since only use the Signal Strength meter built in to my Genie (or earlier DTV receivers prior to the Genie). I have a wireless baby monitor that I aim the camera at the signal strength screen on my TV, take the remote out to the dish and aim it. The directv system won't connect to the wrong sat so I never have the wrong sat issue. The baby monitor works great and is much cheaper than the high priced meters. I did have to buy a new battery for the remote a few years back that I think was in the $5.00 range.
    Actually, the exact same scenario can happen with a Genie that the OP is describing. The Genie does tend to be better, but there are a number of satellites that will cause a few transponders to light up on any DirecTV receiver.
    Good job! Well done. It's nice when posters come back saying they found the answer to their problem.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
