- sailor_louExplorerMine is at the bottom center (about the same height as it would be in a car/pickup truck) and we have had no issues. Based on the responses here it appears both locations work fine.
Lou
05 Travel Supreme Envoy - turbojimmyExplorerTop center of the windshield for me too. Works at the tolls and the high-speed lanes without issue.
- Dale_TravelingExplorer IITop center also. And don't forget, if you bring along the toad with a pass remove it and wrap in foil or inside original RF shielded bag it came in so you don't get charged twice.
- STBRetiredExplorerTop center of windshield.
- Dr_JayExplorerTop center never had a problem.
- esyersExplorerOurs is on the top center of the windshield......never had a problem.
- Dutch_12078Explorer III
sch911 wrote:
Ours is in the bottom center and has never failed to work correctly.
X3 - sch911ExplorerOurs is in the bottom center and has never failed to work correctly.
- jplante4Explorer IIBoth EZPass and the Sunpass from FL are mounted on the bottom of the windshield on either side of the center. Works just fine there.
- Sam_SpadeExplorer
dmctlc wrote:
Where do folks mount their EZPass on their windshields for MA. and probably any state that has an EZPass system?
Thxs
With a class A, I don't see why the question.
Why not near the top of the windshield in a fashion similar to a car or truck ??
Now.....with a C that has an overhang, I've found that mine works OK at the BOTTOM of the windshield, where there is a clear line of site to the reader devices mounted overhead.
38,778 PostsLatest Activity: Jun 10, 2026
