haddy1
Mar 09, 2014Explorer II
If your dish at home is the same as the one on your RV, the Genie will not know that it has been moved and will power up just fine. If not the same, you will have to run setup again. No big deal, but MAKE ABSOLUTELY CERTAIN that you select the proper dish. There are a lot of combinations to choose from and several are quite similar.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
