Bill_Satellite
Mar 09, 2014Explorer II
Go outside and look at the antenna on your roof. If it's high up you might take some binoculars. You are looking for not only what the LNB looks like but to see if there is a green square label on the housing near the base.
If your home dish looks like this then no setup change is required. If it does not then a change will be required but takes less than 5 minutes.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
