cubmaster252
Mar 10, 2014Explorer
haddy1 wrote:
If your dish at home is the same as the one on your RV, the Genie will not know that it has been moved and will power up just fine. If not the same, you will have to run setup again. No big deal, but MAKE ABSOLUTELY CERTAIN that you select the proper dish. There are a lot of combinations to choose from and several are quite similar.
X2. We have the same dish on the house as we use in the RV. We just plug the Genie in. It does not need to be reprogrammed each time if you have the same dish.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
