kellertx5er's avatar
kellertx5er
DirecTV/SWM/SD DVR
We have been using an old 18" dish with two cables, each running to a separate SD receiver. We recently upgraded to two SD DVRs. For full functionality, the DVRs need two cables each or a SWM setup. We have been using them with only one cable and living with the limitation. What would I need to add to make this a SWM setup and be able to use both tuners on each DVR with only one cable to each? The DVRs are R15-x00 types if it matters. I'm not interested in spending much $$$ on this. If it's over $50 I probably won't do it.
  • ken burke wrote:
    Is the SWM dish heaver than the 18 SD dish?
    ken
    Yes, it's a full array dish which is larger and capable of receiving multiple birds. And there is the additional hardware for setting the skew.
  • ken burke,
    You can purchase additional coax. When/if I get a portable SWM dish it will include 50' and 100' coax and I would use both when required. The stated limit is 150'. Make sure you get quality coax and connectors that will support the higher SWM bandwidth.
    FYI From our DTV installer: DTV is now using high quality RG6 coax, L1RC SMS Ultimate compression fittings and barrel connectors HF-81 with a yellow insert. The Genie uses additional coax bandwidth so this equipment is recommended. Our 8 year old compression fittings installed at home by DTV can have a coax shield contact problem and ours were all replaced by DTV when we upgraded to SWM.
  • The DTV installer also said that they no longer ship equipment to a user because there were to many problems with faulty installations.
    I'd guess that if you buy the equipment elsewhere and then need DTV help it will be on your dime.
  • They usually do not provide a tripod but rather a non-penetrating roof mount. If you need more than 20 feet of cable, drop by Ace, Lowe's or Home Depot and grab yourself an extra 50 (or a couple of 50's) and hand it to the installer.
    Bill, tell me more about that non-penetrating roof mount. Many times a roof mount would has made setting up easier than a tri-pod. Once I had to run a cable across a park road to get a view above the trees.
  • Imagine a metal grid on the ground with space to place 6 concrete cinder blocks and a metal pole rising from the center. That's a big heavy unit but it works very well until it's time to move.
  • Oh, your post says roof mount. You don't put that on the roof do you?
    DesertFiver wrote:
    Exactly...
    Not quite.
    Interesting statement because this is EXACTLY what I used when I had the same SD DVR. One 18in dish, 2 lnb, 1 multi-switch and 4 RG6 cables.
    Two cables to each receiver.
    I used that setup for 2 years and sold the MH with it working EXACTLY.
    This system was EXACTLY what was installed in my home by Directv.
  • I said that because he would also have to run 2 additional coax cables so just adding the switch does not solve the problem....exactly.... More work would need to be done.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
