georgelesley's avatar
georgelesley
Dish hopper 3 rv upgrade?
I want to upgrade our home hopper 2 to a hopper 3. We have the Winegard traveler SK1000 automatic dish. I am getting mixed info. Winegard says no way. I mentioned the DPH42 switch and they said it has never been tested in that application. I mentioned changing the LNB and was told the unit will not communicate correctly with the hopper 3.
I have spoken with two dish installers, one said it worked but seemed a bit vague about it and said it took some fiddling with it and required some different steps when activating the system. The other tech it can be done.
We have a tech scheduled to come to our home this week to upgrade our hopper to a hopper 3. I sure do not want to cause a problem where none exists now.
Anyone done this upgrade with the same equipment and know anyone that actually does it successfully or is Winegard correct and it cannot be done?
  • I used to work for Winegard and they are the least willing bunch of folks to address changes that I have ever seen. They would much rather say "No, you can't do that" than try to figure out if there is a way that this could be done. I know they are a very big company with lots of people who keep their jobs by saying NO to everything but Winegard is a much better company than this and they need to embrace change much more readily.
    I really like the Winegard products but no company is perfect.
  • want-a-be wrote:
    You would think the manufacturer of the dish would know a little more about what will work with their product!!!
    Good Luck
    They don't. It also took them several years to get the DTV setup fixed for the SWM that customers fixed probably 2 years before. They still can't figure out how to get EA on DISH which most on the east coast have had for many years. But they probably are busy working on some new whiz bang OTA digital free TV junk.
  • TechWriter wrote:
    But they don't.
    Yes, you can use a DPH42 switch with a standard Winegard Travler SK1000.
    Here are the Instructions
    Looks like the blog entry 6/17/2017 is the right one to use and answers most of my questions. Do three cables come from the roof to attach to the DPH42 inside? According to the installing tech he put a solo node under the traveler base when installing. I assume that goes away?
    Looks like the diagram on page four of the instruction explains it all very well.
  • TechWriter wrote:
    But they don't.
    Excellent!!! Thanks.
    But they don't.
  • There are instructions around for an unsupported, DIY LNB upgrade that claims to make it work. You should able to find it with a little Googling.
    I’ve had several conversations with Winegard regarding this and eastern arc support. They adamantly refuse to consider a future upgrade for either.
  • You would think the manufacturer of the dish would know a little more about what will work with their product!!!
    Good Luck
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Jul 28, 2025
