Gonzo42
Jun 16, 2014Explorer
I'll try to get some more photos for you, but in the meantime, in the first pic, the right-angle bracket and hinge are standard Home Depot parts. The All-thread and faucet knob are, also.
For the elevation adjustment, observe a small diameter all-thread on the lower right going through existing holes (nowhere did I drill holes in the existing dish). There is a small block which was a junk item in my garage which was a steel block with one simple hole non-threaded and it fits over the small all-thread. Then it also had a threaded hole at right angles to the smooth hole. I used regular stock fasteners, including some nylon locknuts.
Now in the second photo (azimuth adjustment) I have some PVC pipe the same inside diameter of the tripod mast and in the middle is a PVC straight coupler. Some sheet metal brackets hold two more of the same hinges to the upper and lower PVC with the coupler between. You can see a chunk of straight metal cut down so the two hinges then line up. The lowest PVC is held with a screw in the tripod base so it doesn't move. There is grease between all the moving parts and the all-threads.
Notice at the bottom that I did cut the mast so there was a short piece at the bottom. Yes, it is a little bit wobbly but once aimed, no problems. Also I hung a hook where I might have to hang a weight if there is wind.
My main purpose was to eliminate the muscling around usually required to get the antenna aimed. I use an app to get the azimuth and elevation numbers for wherever we are and then use a compass. From there its only a matter of using the signal meter and the two knobs to tune for max signal.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
