bobandvicki's avatar
bobandvicki
Dish receiver question with portable winegard 1518
want to upgrade my receiver so I can use the dvr - was told needed the 612 receiver because of my portable winegard but have read many complaints about freezing and noise - anyone comments / opinons would be appreciated - thank you - bob
  • No dual tuner receiver is going to work well with the Dish service and a dome type unit (roof or portable). The dome contains only 1 LNB and the Dish service comes from 3 satellites so unless the programming is coming from the same satellite the 2nd tuner will fail. Additionally, only the primary tuner can cause the antenna to move so if the secondary tuner needs different programming it cannot move the antenna.
  • I'm using a Winegard Anser with my 625 dvr without any problems, fwiw.
  • I have not heard that you could only use a 612 and don't think that is true.
    That said, I do currently have a 612 and it does freeze up regularly.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
