- Bill_SatelliteExplorer II
Busdriver wrote:
My revciver is bad
That would do it as well! Thanks for the update. - BusdriverExplorer IIMy revciver is bad
- Bill_SatelliteExplorer IIThe dome antennas can only "see" 1 satellite at a time. When you have the cover off and you change channels on the TV do you see the antenna move and point toward the different satellites? Are you using more than 1 receiver or a DVR (bad)? Are there any trees in the areas? The 3 satellites span almost 20 degrees of sky.
- steveh27ExplorerThe small dish inside the tailgater can have a difficult time locking in all the sats if there are any trees or other potential obstructions. Frequently when I channel surf it will want to search again for sats.
- ORbikerExplorer
Busdriver wrote:
My dish tailgater will no pick up all the sat, everything seems to be working when I take the cover off it
Is the handle pointing north?
Are the cables good?
Are the RV cables good?
Try going straight to the box from the tailgater with a short good cable. KEN
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
