wd's avatar
wd
Dish TV Connections
I made the mistake of asking Dish Customer Support this question. of course they didn't have a clue.
I just got a new motor home and it has 3 tv's. I have a portable Tailgater. What would I have to do to have a Dish connection for all of the tv's? Hope my question makes sense...……...Thanks
  • You absolutely can connect a VIP 211Z to multiple TVs. The 211Z has two outputs. First is the HDMI output which is high def. It also has a composite (Red/White for audio and yellow for video) which is standard definition. The way I have done this is to place the receiver near the most important (living room?) TV and connect with HDMI. Then get an RF Modulator that converts the red/white/yellow connection to coax. Once this signal is converted to coax it can be distributed to the other TVs via the camper's coax wiring, if available. Another method, which I have not tried, would be to utilize a wireless HDMI transmitter/receiver. There are units that have one transmitter (connected to the HDMI output on the receiver) and multiple receivers which can be attached to the TVs. Again, I have not tried this method. The transmitter/receivers can be expensive. Please note that in the methods above, all TV's must watch the same satellite channel. HOWEVER, I also connect the OTA antenna to the main TV coax input so this TV can watch OTA while others can watch sat signal. Sorry for the lengthy post.
  • Dutch_12078 wrote:
    Which receiver do you have?
    I have the VP211z
  • you need an antenna and receiver that can support multiple indepedent tv's. we have a winegard trav'ler and a dish vip722k rcvr/dvr that feeds two sets. suggest you call Solid Signals at ?1 (877) 312-4547? for some straight answers.
  • Johno02 wrote:
    Real simple if you can watch the same thing on all three, but if you want each to be different, its get a LOT more complicated. That needs a receiver for each TV.
    I couldn't get it to work on my old MH. Dish said it wouldn't work with splitters so I ran a dedicated wire to only one of the tv's
  • Real simple if you can watch the same thing on all three, but if you want each to be different, its get a LOT more complicated. That needs a receiver for each TV.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 31, 2025
