Kountryguy's avatar
Kountryguy
Dish TV
I have Dish TV and am using a Wally receiver. What determines if a channel is HD or SD? The SD stations do not fill the screen. Any thing that can be done? Thanks
  • HD and SD use different aspect ratios. And movies use another different aspect ratio.
    This site has some info that will help: https://www.rtings.com/tv/learn/what-is-the-aspect-ratio-4-3-16-9-21-9
    When the aspect ratio of the content you are trying to watch doesn't match the aspect ratio of your TV, you'll usually end up with black bars.
    Depending on the type of mismatch between the picture and the display's ratio, the black bars appear in different places. Content wider than the screen it is played on will have horizontal black bars, while content that is taller will use vertical bars.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,795 PostsLatest Activity: Mar 27, 2025
