- mr__edExplorerThanks for tne information, friends.
- coolmom42Explorer IISSD drives are solid state and don't have to spin like a regular hard drive. They are blazing fast, and often are used to hold the operating system of a PC, so the boot up is fast.
HDD drives come in different speeds. It's quite likely a new PC will have a higher speed hard drive than an older one. So a new larger drive might actually run faster than an older smaller one.
Any HDD will run more slowly if the disk is fragmented. That used to be something you had to do manually. Windows 10 calls it "disk optimizer" and by default it runs weekly, which should be more than adequate. But you can also run it manually if you want to. - Triker33ExplorerSSD drives can lose some of it data over time. So backup often.
- IroverExplorerI upgraded my 2103 Acer NE-522 from 4 gb Ram and 500 GB to 8 gb Ram and 1 TB, it boots faster and is much quicker loading programs! Just don't ask for specifics! LOL!
- bighatnohorseExplorer II
Heisenberg wrote:
The SSD will boot up in less than 20 seconds. It is faster overall than the HDD. Size does make a difference especially when you get some data on them but the difference is not linear. In other words a 500 GB is not twice as fast as a 1 TB.
The SSD drives are amazing - boot up is much, much quicker. - 2012ColemanExplorer IIThe thing that makes hard drives slower is fragmentation. Regular disk defragmentation can significantly improve your computer's speed, especially when launching programs and working with larger files. It occurs when the file system cannot or will not allocate enough contiguous space to store a complete file as a unit, but instead puts parts of it in gaps between existing files - usually those gaps exist because they formerly held a file that the file system has subsequently deleted.
You can schedule regular disk defrag during downtime. - HeisenbergExplorerThe SSD will boot up in less than 20 seconds. It is faster overall than the HDD. Size does make a difference especially when you get some data on them but the difference is not linear. In other words a 500 GB is not twice as fast as a 1 TB.
- rk911Explorereverything else being equal, no, at least not in any noticeable, meaningful way.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Oct 16, 2025
