n7bsn
Jul 25, 2014Explorer
Bill.Satellite wrote:
That is incorrect. All signals are UHF and VHF just as they always have been but in the past we broadcast analog signals on UHF and VHF and now we broadcast digital on UHF and VHF (along with a bit of analog).
The antenna on your RV receives UHF and VHF so the analog / digital "thing" did not change this. However, now, 70-80% of all programming is on the UHF frequencies so having an antenna optimized for UHF will certainly help. ...
Bill, you are generally knowledgeable, but in this case, you are wrong.
All RF signals are analog, the only different between "analog" TV and "digital" TV is which analog modulation technique is used.
That also holds true for digital Cable, which uses different modulation then Broadcast.
I can post the Fourier transform to show this if you really want... (only kidding, I don't think the forum supports those special characters)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
