vermilye
Nov 30, 2015Explorer II
wa8yxm wrote:
Using the phone as a hot spot WILL run the battery down very fast.. UNLESS (read on)
And battery life is measured in cycles assuming no abuse. also the speed of charge/discharge affects overall battery life... So I'd say the Verizon hack was well.. Not exactly lying, but not telling the full story either.
now for the UNLESS.
plug in the charger cable and don't even use the battery.. That's what I do when I hot spot.
The problem with plugging in the hotspot is that many will not operate without a battery in place, and when the battery is in the unit, it is usually being charged if the charger cable is plugged in.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
