- Bill_SatelliteExplorer IIRight, you cannot change the settings unless you are first pointed to the satellite with a non-swm antenna. You have to be able to go through the complete setup routine or it will not save the correct settings.
- captron33ExplorerEven with the sat wire disconnected the switch and dish settings will not stay changed....very frustrating believe me. I am thinking about just getting an after market reciever and hope it works. Is it true dtv will not have any satellites except hd after 2019???
- Bill_SatelliteExplorer IIA) The D12 is still available should you want one. It won't come from DTV but it is available.
B) The H24 (or HR24 if you like a DVR) will work just the same as a D12 after you make some settings changes in the "satellite setup" menu.
I find it highly unlikely that the D12 will not let you update the settings but I am not there so I will just have to go with the information you provide. It's more likely that the antenna you are connected to is not letting you do the necessary changes as the default setting for a D12 is 18" round / multiswitch. - CA_TravelerExplorer III
captron33 wrote:
Upgrade to a new HD dish and receiver. DTV will not broadcast SD after 2019.
Sooo what are my options, DTV doesn't supply that type reciever anymore. - JohnnyTExplorer IIMoved From Class A Forum
- donn0128Explorer IIGontact dtv for a new updated one.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
