monkey44
Apr 09, 2017Nomad II
Dual monitors Q
Trying to set up dual monitor on a desktop -- one to process landscape photos and one to process portraits without swinging the screen back and forth each time and changing setting each time too -
I can get both to operate, but when I put settings in one, it duplicates to the other - I can't make one portrait mode and one landscape mode ... and when I upsize resolution on one, it also upsizes on the other -- which I can't do with both.
PC is custom desktop Win 10 Pro with Intel i7-7700k processor, ASUS Z270E MB ... and installed Nvidia 1060 GC, and both monitors run thru GC, one on the DVI port, and one on HDMI port.
I should be able to show same image on both screens
Monitor One = BENQ SW2700PT at 2560x1440
Monitor Two = ASUS PA248Q at 1920x1200
Every time I change settings it changes on both, even if I separate each one, and change each one to its own settings ...
Am not as Tech Dumb as I once was, but still pretty much a 'novice' and stumped on this one =
A thought: Do I need identical resolution (or brand and size) to make this happen ... that would suck, but could change to identical if necessary ...
