MEXICOWANDERER's avatar
Apr 17, 2014
DUMMY'S QUESTIONS
I am allowed only a laptop down here in Mexico and I do not want to buy a space eating desktop with an operating system in español with keyboard.
I am getting OLD. I need a bigger screen, a bigger, more comfortable keyboard (preferably wireless) and a comfortable wireless trackball.
I have an older el-cheapo Compaq Presario CQ57 (Checker Cab Grade) laptop. It has a 15.7" rated screen.
I would love to have this critter fully operational with the lid closed tight. Is this possible? Use maybe a 22" screen, and the wireless stuff maybe eight feet away from the computer.
Of do I need to have the lid popped open. Dust is the issue. Lots and lots of grit and powder.
Is the Compaq graphic card inside so lousy that everything is going to look crummy on a bigger screen? Can I save money and not lose much by selecting a same size screen with fewer (pixels?)
The sound card sucks. So I just ordered up one of those plug into the USB 2.0 port gizmos that converts everything to 3.5 mm plugs. It's supposed to have it's own vastly better built-in sound card.
There's a 20-dollar supposedly great LEPAI amplifier available that can power better speakers. The computer speakers I have used in the past sound like something you used to hang on the window in a drive in theater. Horrible.
Is there such a thing as bookshelf speakers that the Lepai can power to make decent sound, like for movies and music? I know I am going to need a powered subwoofer to get decent explosion sounds and bass guitar and organ.
  • Since your laptop is old, it probably doesn't have an HDMI port. Monitors have been using HDMI and the old pin cords for several years. Make sure when you buy the monitor, that it still has the old pin connector so it will connect to your laptop. They may have started leaving them off to save money.
    Bill
  • dan-nickie wrote:
    The only way I have seen to use a laptop in the closed position and external monitor is with a Docking Station. The manufacturer specs does list a part number for one.
    Not true. True docking stations no longer exist. There should be a monitor jack on the back side of the laptop. you'll need to set the laptop to use an external monitor. Its one of the function keys to set it up. And you'll have to make sure that the power management is set to not shut it off or put it into sleep mode when closing the cover.
    SRS labs makes software that dramatically improves sound from laptops and desktop computers. I use it on an Acer netbook. SRS Audio Essentials
  • In the contol panel select the power options, select advance tab, at the lower portion of that tab is what you want the computer to do if you close the lid. one of the options is to "do nothing".
  • Check display settings and power settings
    You should be able to tell/set it, so it does not turn off when closed
    If push comes to shove you can cut off the little push button on the switch that is pressed down when the lid is closed
  • The only way I have seen to use a laptop in the closed position and external monitor is with a Docking Station. The manufacturer specs does list a part number for one.
    I figured you could just use the Headphone out jack to some powered computer speakers/sub.
    I also think there are quite a few wireless mice that will work at that distance.
