Rbertalotto
May 09, 2016Explorer
Easy Outside USB jacks...
I wanted to be able to charge my devices while I'm sitting outside under the awning. The easiest method was with this device.
TOPGREENER TU21548A 4.8A Duplex USB Charger Outlet
Simply replaced my duplex with this device...Done!
Upgraded High Speed Charging Tech: World's First Smart Ultra-High Speed Dual USB Charging In Wall at 4.8 Amp, 24W, 5VDC
Charging-Smart Technology: Dual "Smart" USB Ports Precisely "Read" the Power Need then Maximize Charging Efficiency
Design Innovation: Interchangeable Face Cover. 3 Color Face Cover Included: White, Black, Light Almond
Two TR Tamper-Resistant Outlets enhance electrical safety, preventing the attempting to insert objects into the outlet; Meets 2011 NEC
Compatibility USB 1.1/2.0/3.0 devices, 2 USB ports total 4.8 Amp, 5VDC; Two TR Receptacles 15 Amp/125VAC; UL lsted; 2 years warranty; Back & side wiring easy installation. Wall plate not included
About $20 on amazon
http://www.amazon.com/TOPGREENER-TU21548A-Resistant-Receptacle-Interchangeable/dp/B01BTC5I5O?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
About $20 on amazon
