landyacht318's avatar
landyacht318
Evolving USB power
I've no devices which can draw more than 1 Amp through a USB port, never the less my several outlets can handle 2.1a or 3.1a total.
My favorite USB source is my Blue Seas:
https://www.bluesea.com/products/1016/Dual_USB_Charger_Socket
It maintains 5.09v under a 1 amp load, where as my other sources fall below 5v. This source and a short Micro USB cable can recharge my Samsung galaxy S4 mini phone noticeably faster than any other USb source I have.
It has a 15mA parasitic draw.
I just Noticed that Blueseas has a new version out available in January 2016, capable of 4.1 amps, and it only has a 1mA parasitic draw.
https://www.bluesea.com/products/1045/Dual_USB_Charger_-_Socket_Mount
I've not kept up with USB 3.0 or how much amperage newer devices can demand. I really like BlueSeas products and would certainly get this, if I required it, but I have 8 different USB options now and only 2 devices which require USB to charge.
But some on here might be more latest and greatest gadget savvy than myself and find the second link to be interesting.
Or perhaps want to talk about and inform us Neophytes where the USB standard is likely to go in the future
  • First you need to resize your pix.
    I plugged in my iPhone 6 with a purposefully drained battery to around 40%. Plugging into my less than awesome Ford Sync port, the BEST current I saw out of that USB Jack was 440ma. Turned on the GPS and there was no change in current draw. After a few minutes the current settled back to around 350ma and stabilized there. That's Ford, not the phone because I've seen it run at 1500ma+. Starting at 40% with WAZE and all my normal push services on, at the end of my ~90min trip, the iPhone was now showing 36%.
    Backwards......
  • TheBearAK wrote:
    Don't know about other phones, but Apple's charger for the iPhone is 1A. In my experience (going on 4th battery), charging it with a larger charger can charge it up quicker, but will reduce overall battery life.
    For example, charging it with the iPad charger (2.1 amp) can charge it quicker, but the battery gets noticeably warm and warm/hot=bad. It also seems to not last as long per charge.
    I would guess this would go for any lithium rechargeable battery.
    Ive not seen that at all. The regulator should be in the phone and not dependent on its power source since the designer has no clue what the USB current source is. The only time mine warms up is when charging with WAZE and my NAVIGON app running
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
