TenOC's avatar
TenOC
Nomad
Sep 30, 2017
ExpressCard/54 will not stay plugged into laptop
I have a HP laptop. It does not have USB3.0 ports so I got a ExpressCard/54 that has USB3.0 ports. I use the ExpressCard/54 to connect an external USB3.0 hard drive that I use for backups. The problem is that the ExpressCard/54 will not stay plugged in. The smallest amount of vibration and the card will loose connection with the laptop. Thus my backup does not complete.
I have tried 2 different ExpressCard/54 cards. Any suggestions?
  • ReadyToGo wrote:
    USB 3 devices are backward compatible with 2. You don't need the card. Take it back.
    THIS....probably.
    The performance of your 3 device will be limited to 2 specs when you "convert" anyway.
    Try it without the converter.
  • USB 3 devices are backward compatible with 2. You don't need the card. Take it back.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
