J_herb's avatar
J_herb
Explorer II
Jul 22, 2016
External laptop coolers
I have a ACER net book laptop with windows 10 and 6 GB of ram and intel 877 processor that the fan runs all the time but the laptop runs warm not hot. Do you think a external fan is needed ? it's not dirty as I have opened it up and cleaned it. The laptop runs fine other wise. Thanks in advance Jay
  • WyoTraveler wrote:
    Yes the external fans do work. DW uses an external fan on her Acer laptop. Her external fan is called "Connectland accessory". It plugs into a USB port. Her Acer has always overheated when purchased new.
    x2
    Probably not needed but sure knocks down the case temp
  • Yes the external fans do work. DW uses an external fan on her Acer laptop. Her external fan is called "Connectland accessory". It plugs into a USB port. Her Acer has always overheated when purchased new.
  • Laptop's have an internal temperature and the fan kicks on to prevent overheating. Although your computer is clean the inside is really where it counts. Excess heat will reduce the life. Here is an article about cleaning the internal but I know a lot of manufacturers void the warranty if tampered with.
    clean it
  • You may have to many applications running in the background. Go to your task manager and see what all is open and shut down those things not needed.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
