Yellowboat_'s avatar
Yellowboat_
Finding DirecTV Coax Cable
In our new coach Winnebago directed one line out from our satellite antenna to the front of our coach and the other line out to the rear bedroom.
I would like to identify the coax running from the antenna to the rear bedroom so that I can redirect it to the front to connect to my DirecTV satellite box.
I have access to a bundle of coax wires and I'm trying to identify the wire running from the antenna to the bedroom outlet. I tried using ohms to check continuity on the outer shield wire. I find that all cables show continuity even when I have disconnected both ends of the coax. There must be a connection and a ground somewhere in the coax wire system.
Does anyone have a method of identifying coax cables in the middle of a run?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 28, 2026
