AllegroD's avatar
May 30, 2023
Garmin 1095 Mount
For those that have a 1090 or 1095, how did you mount it? We have a 2019 Tiffin RED 37BA and want to mount it to the right of the driver. Have not tried to mount it at all, yet.
  • dkilley wrote:
    Hi. To mount our 1090 we purchased a flat plate from Amazon that has an adhesive sticker on bottom to attach it to our dash. Our dash is not smooth so the suction cup provided does not stay attached. The flat plate must be same size or larger than the suction cup or it will not work.
    We love the unit and certainly enjoy the large screen.
    Great idea. Do you have a link? My initial search found a lot of metal ones, a few plastic but many of the plastic have rough surface.
  • Hi. To mount our 1090 we purchased a flat plate from Amazon that has an adhesive sticker on bottom to attach it to our dash. Our dash is not smooth so the suction cup provided does not stay attached. The flat plate must be same size or larger than the suction cup or it will not work.
  • agesilaus wrote:
    Well my Garmin RV990 I asume is similar. The suction cup stopped working and I ended up screwing it to the center overhead. Depends on how much a couple of screw holes bothers you in the dash.
    Thanks. I assume you mean RV890. We don't mind using screws when needed.
  • Well my Garmin RV990 I asume is similar. The suction cup stopped working and I ended up screwing it to the center overhead. Depends on how much a couple of screw holes bothers you in the dash.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
