woodworker414's avatar
Nov 04, 2021
Garmin Basecamp Problems
Good morning fellow truck campers.
I recently purchased the Garmin RV 890, I really like it. I have always purchased a Garmin gps. I have been learning Basecamp, I like it.
I can pick my own route and then export it to the RV890. When I open Basecamp and connect the gps to my laptop, Basecamp opens a small window, "Problem connecting to the device, error code, garmin/gpx/ current.gpx. I googled the error code and Garmin gives steps to delete the issue. I follow the step and deleted the corrupt current gpx file.
Then I start to mark my route, by placing waypoints, but somewhere on the route Basecamp does not follow the route that I have marked and willy nilly goes where it wants but will come back to the last waypoint that I had put on the map. Well I don't want to wander all over the countryside., I want to go down the roads I picked. I have called Gamin numerous times. The last time the guy said I see you have called before, Yes, because the issue has not been solved. And he kinda talked to me as if I was a waste of his time. UUUMMMM I was really looking forward to using Basecamp to explore.
Hope I explained this clearly. Has anyone who uses Basecamp had this issue?
Does anyone know of a alternative program that I can use instead Basecamp, Or a different gps device to replace the RV890.
Any input will be appreciated.
