- Fishy_Old_ManExplorerWOW! Thank you so very much for the terrific replies. I now have a direction!
- SCVJeffExplorer
Isaac-1 wrote:
its usually x3 the horizontal error
Be aware that due to the way the non-augmented GPS system works elevation is their least accurate dimension. - n7bsnExplorer
STBRetired wrote:
My Garmin Dezl760LMT will show elevation.
As does the RV760, since it's based on the Dezl
The newer RV660 and RV770 add the upcoming road profile (grades) - Isaac-1Explorer IIBe aware that due to the way the non-augmented GPS system works elevation is their least accurate dimension.
- Desert_CaptainExplorer IIIYou can also get elevation from your i-Phone by accessing the compass function.
:C - ScottGNomadAll GPS engines have altitude data. I don't think any modern unit fails to display it some how. Even in automotive circles it's available in a sub menu.
- 4aSongExplorerOur Garmin 2797LMT has elevation and I would assume most have that feature available. A phone app would be another option.
- 2oldmanExplorer IIMy 660 Garmin allows display of almost any parameter of your journey. Bottom right corner tab. Just tap it to see menu.
- accsysExplorerI think most current GPS units will display the elevation IF you know how to get it. For instance the the Garmin 56 I use in the Libby requires me to tap on the arrival time to get to an option for many other things to display in that space. Elevation is one of those options.
- fj12ryderExplorer IIIMy Nuvi 2539 has elevation function.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
