TenOC's avatar
TenOC
Nomad
Sep 20, 2016
Hard Drive Lost Format and Name
HP xw8600 PC with Windows 7 Ultimate and ESET antivirus all up to date.
I have 3 hard drives in my computer --- C: is the operating system, --- F: (2Tb) is for data and --- V: (3Tb) for for backup using Symantec System Recovery 2013 R2
The last time I checked there was about 500Gb of free space on the V: drive. Today I had a backup failure. After rebooting I find that the V: drive has lost its format and name. Windows Explorer says that I should reformat. This same thing happen about 6 months ago also.
Disk Manager show the V: HD but without any name and 100% free space.
I know I can reformat, but I am more interest in what went wrong.
The 3Tb drive has been working with no problems making daily backups.
Any suggestions?
Could it be that I hit the 2.2Tb limit? Disk Manager show it as a 2794.39 Gb.
  • Your graphic and description is not what you typically see corresponding to an issue with the MBR. More like an issue with hardware controller. The question of whether its the MB or on the drive itself?
    Are you running 32bit version of WIN 7 Ultimate? If that was the case, you'd only see 2T as usable storage. It would ignore the extra space.
    You can avoid drive space limitations by installing the HD in an external USB2/3 enclosure that has built-in firmware support for larger drives. Most do nowadays.
    Windows 7 - 64 Ultimate
  • Does your WIN x64 PC use GPT? Then it can utilize internal SATA drives larger than 2.2TB. The 2.2TB limitation comes in when using the older MBR NTFS standard.
    Generally, not an issue either way if using an external USB drive enclosure with firmware support.
    Yes it is GPT. I have been able to see the full 3Tb of the drive for a long time -- until this happen. In the screen capture photo you can see that Windows Disk Manager shows the full 3Tb as available but not formatted.
  • That being the case, I would tend to believe its a hardware controller or cable issue. So long as the drive's SMART is not indicating an unusual number or increasing reallocated sector count? In any case, the drive could be on its way to failure.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
