I_rv's avatar
I_rv
HD on dual tuner receiver
I have dish net. vip622 receiver and on tuner 2 you only receive sd however i find if i have the receiver set to single mode(which i usually do)i the receive HD on all tv's. when talking to a friend who has direct tv he said he has HD on both modes,just wondering if this is true.
  • Changing the 622 to single tuner negates the dual tuners so you have only one tuner available for use. If you want HD you MUST use the HDMI (or component) connection. If you are sending a signal to a 2nd TV via coax it will be in SD no matter how you have the receiver setup. Dish is the only one that makes a dual tuner box. With DirecTV you must have 2 separate receivers on 2 separate TV's to watch 2 separate channels. That makes the HDMI HD connection simple.
  • To answer the OP's question more directly, DirecTV's receivers are either HD or SD and do not "change" the way you've noticed that the 622's does. The HR44 Genie has 5 independent tuners all of which are capable of displaying HD.
  • Direct TV uses different receivers with different capabilities. Replacing your 622 with a Hopper and Joey on Dish would also give you HD on both TV's, plus independent access to the Hopper's three tuners and DVR recordings.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
