LouLawrence
Aug 03, 2021Explorer II
The outside cable connection is intended for cable only in many RV's. It's hard to know how it's wired unless you can get hold of a wiring diagram. As mentioned above, you can remove the power supply (not a booster) from the wall and find the coax marked cable. Disconnect this and and a coax extension to this with a barrel connector and connect that cable to the satellite receiver. If it works then you are lucky and have a direct run from the outside connection to the wall plate. If it does not work then there are splitters between the 2 connections and this line will not work. See if you can find a way to route a new line from anywhere outside (firewall, storage compartment, etc.) to where your receiver is located.
If you were lucky and the satellite works while disconnected from the power supply, all you need is a high quality high-isolation A/B switch. Connect the coax that runs from outside to the 1 input on the A/B switch and the 2 outputs will go back to the power supply and the other to the receiver. Now it's a simple choice between using park cable or your satellite antenna.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
