- docjExplorer
DC&MC wrote:
Would we be able to use a dimmer from Lowes that says LED compatibles, or are our RV 12v lights diff?
The dimmers at Lowes and HD are for 120V AC circuits. However, there are plenty available for 12V LEDs but you're not going to find many at your local stores. You do have to make sure that the LEDs you are working with are dimmable. Not all are.
You can find some examples of 12V LED dimmers by following this link. I've had multiple dealings with this vendor and have been very pleased. SuperbrightLEDs.com - DC_MCExplorer IIIWould we be able to use a dimmer from Lowes that says LED compatibles, or are our RV 12v lights diff?
- GordonThreeExplorerThe physics of how an LED operates makes it incompatible with most incandescent dimmers. Even those that do appear to work are only giving you a narrow range of dimming compared to the incandescent bulb that was replaced.
High end RVs that use digital dimmers (the kind with a wireless or wired remote) will dim an LED better, because they're using PWM technology versus a simple rheostat. PWM uses an electronic switch to turn the light on and off really fast, such that it looks like a steady glow to our eyes. The more off than on, the dimmer the light.
Wireless LED dimmers - IvylogExplorer IIII use the same Dimmer as the halogens that I replaced with the cheap China LEDs without any problems.
- RoyBExplorer III've never used one before but there are many listed on GOOGLE SEARCH
LED DIMMERs
Mouse click on the image for more info...
Roy Ken - WyoTravelerExplorerThey won't work with a dimmer switch. I have a dimmer switch over my driver position in our MH. LED just glows. I had to remove it. Like a previous post mentions try it in a regular socket somewhere else.
- TakingThe5thExplorer
DC&MC wrote:
It was the dimmer. We changed it to an on/off switch and it's fine. We can get a dimmer for led's ??
Some LED bulbs are dimmable, others are not. Then there is the switch ... - DC_MCExplorer IIIIt was the dimmer. We changed it to an on/off switch and it's fine. We can get a dimmer for led's ??
- 2oldmanExplorer IIdimmer switch
- tenbearExplorerDon't just believe the color code of the wires, incandescent bulbs don't care about the polarity so often the builder didn't care either.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
