- Bill_SatelliteExplorer IIMy guess is that it is the dimmer. Most LED's will not function with this kind of a device in line.
- RoyBExplorer III see you mentioned a dimmer switch setup. If this dimmer was for your incandescent automotive type bulbs I don't think it will work on LED LIGHTS... LED lights take a different type of DIMMER system to make them work then the Incandescent automotive type bulbs use.
Lets hope the reverse wires is the problem but in my case here if the wires were reversed I did not get any LED operations at all...
Roy Ken - AdminModeratorSome will do that when they are reversed.
Reverse the wires
Admin - IvylogExplorer IIICheck the polarity but when reversed they usually do not work at all. Try one somewhere else
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
